0 members (),
108
Mod | | | Forums66 Topics128,035 Posts1,055,560 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2008 Posts: 714 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 714 | Hi all, I need to adjust the cables on the stock e-brake set-up on my 57 Chevy truck. What is the correct way to adjust them? Thanks! 1957 Chevy 1/2-Ton TruckIn the Stovebolt GalleryMore pixThe coldest winter I ever saw was a summer I spent in San Francisco M. Twain If at first you don't succeed...skydiving is not for you! If you don't like my carbon foot print, stick it up your Prius!! | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | with the handle fully released, adjust those threaded cable ends so the cable is just tight without actually pulling the lever inside the drum, make both as close to the same as ya can - make sure both nuts are tightened well on each cable to lock the position and hold the tension - then bob's yer unkl  Bill | | | | | Joined: Mar 2007 Posts: 863 Shop Shark | | Shop Shark Joined: Mar 2007 Posts: 863 | Make sure that the brake shoes are adjusted first though..... | | | | | Joined: Jun 2008 Posts: 714 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 714 | What about the cable running from the front of the truck? looks like it screws into a "fork" looking bracket? same thing?
GMCnut, Yes brake shoes are adjusted but still having trouble getting banjo bolt in MC to not leak...
Thanks guys! 1957 Chevy 1/2-Ton TruckIn the Stovebolt GalleryMore pixThe coldest winter I ever saw was a summer I spent in San Francisco M. Twain If at first you don't succeed...skydiving is not for you! If you don't like my carbon foot print, stick it up your Prius!! | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | yes, you want that front section just loose enough so when released that midway "pivot bar" is about like your pic, just shy of the end of the slot, so it has as much forward movement as possible to allow full travel of the handle without hitting the other end of the slot .... also, make sure the wheel in the frame bracket there is lubed, they do tend to sieze up so the cable is rubbing back and forth getting damaged instead of turning
Bill | | | | | Joined: Feb 2010 Posts: 129 Shop Shark | | Shop Shark Joined: Feb 2010 Posts: 129 | If you want to make sure that your rear individual cables are adjusted evenly, you can prop the rear end up on jack stands and gradually pull the park brake handle a few clicks out, until both rear wheels just start to feel resistance from the brakes coming on. I don't know how important that is though.
Ed Miller '58 Apache short Fleetside half ton Napco Falls City, OR
| | | | | Joined: Jun 2008 Posts: 714 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 714 | The cable running back to the "fork" is all the way tight against the bar . But the cable is still very loose and when I pull the ebrake It does not look the wheels up.
1957 Chevy 1/2-Ton TruckIn the Stovebolt GalleryMore pixThe coldest winter I ever saw was a summer I spent in San Francisco M. Twain If at first you don't succeed...skydiving is not for you! If you don't like my carbon foot print, stick it up your Prius!! | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | I'd say you got the front cable for a long bed Jon, might need to change that out for a short bed one - not likely to take up that much slop by cutting the threaded end back, but you might manually pull it tight and guestimate if that's possible
Bill | | |
