0 members (), 102 guests, and 0 robots.
Topics128,048
Posts1,055,540
Members48,425
#677601 09/13/2010 10:16 AM
hi
i have a 235 engine in my apache with a 3 speed gearbox with the lever on the steer .
is there a conversion possible with a 4 speed gearbox from another type chevrolet or maybe a automatic gearbox ?
i want some more speed out of the engine .
is there anywhere a kind of schedule to be found what conversins are possible ?
thanks sofar
aj
desert #677607 09/13/2010 12:59 PM
The 3 speed and 4 speed both have the same finale ratio 1-1 there is alot of info on using a T5 from a S10 pickup here and when I was just in Kansas city this weekend I talked to some guys that did the conversion and they were all very happy with it.
Pete
desert #677608 09/13/2010 1:00 PM
Welcome to the Stovebolt aj. Your best bet if you're looking for more speed would be to focus on the rear end gearing first. In most cases that would be the easyest and least expensive place to start. If that doesn't get you on the autobahn then you might look into converting to one of the five speed transmissions like a T5 manufactured by Borg Warner Automotive. Just for starters try researching in links similar to this http://www.5speeds.com/t5/
Stick with us, don’t be shy about asking more questions and the guys here will get you up to speed.
Denny Graham
Sandwich, IL USA
Denny G
Sandwich, IL
desert #677609 09/13/2010 1:01 PM
Mornin' Peter, see you made it home ok last night. Thanks again for the ride.
Denny
Denny G
Sandwich, IL
AJ
Did you consider simply using a bigger diameter tire? Thats the cheapest way to go.
I used 700 X 16 tires instead of 600 X 16 thats about 10% bigger in diameter so I drive now 10% faster for the save revs in my 48 Chevy Fleetmaster ( in Holland too) costs about €250 here and you have 2 new tires too.
If you use modern tires you have to use a higher profile as what you have now of a combination of higher profile and wider tire that will increase the diameter too.
Next more logic step is to change your rear axle ratio to a lower one there are kits available in the USA starting from around $450.
Finally changing to a T5 it involves changing to an open system requiring a new drive shaft a new back axle and some modification.That should be the best combination but involves allot of....money.
Jianis
