| | | Forums66 Topics128,051 Posts1,055,768 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2006 Posts: 649 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 649 | What is difference between 54 3100 inner fender vs 53 inner fender? Is it just the bolt holes on the front of the fenders? Does the radiator splash panel bolt up? I'm bulding a 54. | | | | | Joined: Jan 2008 Posts: 176 Shop Shark | | Shop Shark Joined: Jan 2008 Posts: 176 | I had an opportunity to buy some 48-53 inner fenders to replace the damaged and bent up original ones on my 55 first, so I took a chance and bought them. Since I still had the original ones, I was able to transfer the radiator splash apron holes over to the replacement parts and ended up with a first rate fit. | | |
