0 members (),
40
Mod | | | Forums66 Topics128,072 Posts1,055,906 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2010 Posts: 15 New Guy | | New Guy Joined: Sep 2010 Posts: 15 | the fender on a 1953 GMC 100? mine is rusted out where the fender bolts to the cowl. i hear its pretty common. i really would rather not buy a replacement fender. unless i really have to. im not afraid to make some sheet metal patches. but i dont know if some one doesnt know of a place that makes a kit to repair this? Fender cowl you can see the rust damage to the fender and cowl. i know i need to replace the inner to outer cowl and outer cowl.
Josh
| | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | I'm sure someone has, but I'd look for a replacement fender first. You may find a damaged one with the pieces you need still good if you don't find a whole one that is usable.
The cowl panels are available from most the old truck vendors so they aren't hard to find.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | I agree with OldSub that finding another fender would be more feasible. Most vendors that sell patch panels sell the cowl panels. I have never seen a patch panel for what you need. I would look for another fender, or possibly you can find one that took a light hit in the front and make one out of two if you like to patch things. | | | | | Joined: Sep 2010 Posts: 15 New Guy | | New Guy Joined: Sep 2010 Posts: 15 | well thanks guys, i'm pretty handy with a tig and sheet metal i will start there and when I re do the truck in a couple 10 years when I have more money I'll do it right. the joys of being 23 and only working for 10.50 a hr.
Josh
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | It doesn't matter what you make an hour but if you are good at TIG, you have the world by the tail! I find it is always more satisfying repairing something than buying a replacement. Good luck on your journey. I completely enjoyed the process and when people asked "how long", I told them ten years. That seemed to be good answer to give! | | | | | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | Go for it! My fenders looked pretty good until they were removed and I found most of the mounting flange area rotted away. If you have the time repairing/reflanging original fenders is better than the thinner repops. If you're paying somebody else it usually costs more to fix one than buy a new offshore pc.
1952 1300 Canadian 1/2 ton restomod You Tube | | |
