1 members (1 invisible),
108
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,196 Posts1,057,395 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2010 Posts: 303 Shop Shark | | Shop Shark Joined: May 2010 Posts: 303 | Does anyone know where you could buy the tool to use to remove the screws that are holding the window regulator and window ventilator parts in on the inside of a 55 2nd series door?? These screws are also used on the inside of the bed panels to hold the rear fenders on (bed fenders screws are bigger though) and door strikers. I have checked with Advance and Auto Zone and they don't carry the tool. What do you call these types of screws?? | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | They are called clutch head screws/bolts. Search on: +clutch +head You will find many references to where to buy tools, including: NAPA, Snap-On, Harbor Freight, McMaster-Carr, and most reproduction parts vendors. | | | | | Joined: May 2010 Posts: 303 Shop Shark | | Shop Shark Joined: May 2010 Posts: 303 | great, thanks for the help, the guy at advance called them "butterfly screws". I will more then likely chage over to a philips head screw when I go to replace them. Thanks again for the help | | | | | Joined: Jul 2005 Posts: 595 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 595 | 86 those clutch head screws.check into "square drive" as the drivers have beter bite than phillips drive. | | |
