| | | Forums66 Topics128,026 Posts1,055,403 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2010 Posts: 74 New Guy | | New Guy Joined: Apr 2010 Posts: 74 | Blew it up all over the highway. I have a 1946 Chevy Stylemaster Sedan with a 216 engine. I was driving down the highway at about 65MPH and it exploded. What are my options as far as replacements go. Should I get another 216, or move to a 235 or maybe even a 302? I am looking for the cheapest easiest solution to get it back on the road again. What's your thoughts?
DG
1946 Chevy Stylemaster Sedan - 216 6 Cylinder 1971 Chevelle SS 1995 Monte Carlo Z34 2005 Corvette Z51
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | 1st choice: cheapest and easiest: probably buying a 216 (bolt right in)
2nd choice: high pressure 235 (1954 or later)
3rd choice: 261
4th and higher choices: GMC 228, 248, 270, 302 (in that order, based on relative costs).
| | | | | Joined: Aug 2006 Posts: 108 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2006 Posts: 108 | My thoughts are, running a 216 at 65mph isn't cool, especially for long periods of time. I would suggest, if you want a highway cruiser that you change over to a full oiler 235 engine with an upgraded tranny and differential. (or keep a spare 216 handy)
The Interstate system was designed and built AFTER 1953 most cars and trucks prior to 1953 were driven on state roads at 50MPH or less.
Best Regards Will
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Man that is rough. Well I guess if you get a good solid engine in there, things should be a lot better. A full pressure 235 would give you a boost in power. However, you may not want to be cruising at 65 mph if you have a 4.11 rearend. | | | | | Joined: Sep 2005 Posts: 1,028 'Bolter | | 'Bolter Joined: Sep 2005 Posts: 1,028 | DG That is rough. I have a 216 in my 53 that I have the same fear. It is ok on the road but I don't typically run it over 55
I just bought a 235 full pressure engine to rebuild so I can have a highway cruiser. I will likely keep my 216 as it is the original
I think a 235 or 261 is the way to go
Rich | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | "I am looking for the cheapest easiest solution to get it back on the road again. What's your thoughts?
I'd look for a running high-pressure 235.
| | | | | Joined: Sep 2005 Posts: 1,028 'Bolter | | 'Bolter Joined: Sep 2005 Posts: 1,028 | | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | DG, while I think the GMC engines were a very superior engine, I would not recommend trying to put one in a passenger is not a quick or cheap ordeal. The engine is 1 1/2" longer and the oil pan will not clear your tie rods, etc. It has been done, but it wasn't easy. Take the advice of Chevy guys and put a Chevy in that bolts right in. | | | | | Joined: Jan 2006 Posts: 127 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2006 Posts: 127 | I have a 235 out of a 1957 w/ about 12k mi on it,and a 1959 235 with 80k on it both are complete engines. Starter,generator,flywheel,clutch and bellhousing. if you need help let me know. | | | | | Joined: Apr 2005 Posts: 1,107 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,107 | mr. giant i see your not that far from me. | | | | | Joined: Apr 2010 Posts: 74 New Guy | | New Guy Joined: Apr 2010 Posts: 74 | I mis-posted in another thread by accident... sorry,
I bought a nice 235 yesterday, all rebuilt, new carb, fuel pump, and water pump. Stainless steel valves and so on. Full pressure 235 not an oil dipper. I will post some pictures tonight or tomorrow. If anyone could tell me what will need to be swapped or replaced to get this thing to fit I would greatly appreciate it. In addition the gentlemen who sold me the engine gave me a practically new clutch to go along with it, and a flywheel.
DG
| | | | | Joined: Apr 2009 Posts: 164 Shop Shark | | Shop Shark Joined: Apr 2009 Posts: 164 | if it is a 55 2nd to 62 235 you should get a water pump relocation plate so the old style water pump can be used. | | | | | Joined: Mar 2010 Posts: 843 Shop Shark | | Shop Shark Joined: Mar 2010 Posts: 843 | DG, have you considered converting the rear end ratio to 3.55? I just did that in my '36 pickup and it drops the engine revs about 17%
Ray
| | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | So nice to see so many replies saying keep the six. Glad no one suggested a SBC! | | | | | Joined: Mar 2008 Posts: 374 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 374 | I always suggest an SBC. " Southern Blonde (or Brunette) Chick"...  Cool deal on finding and obtaining a full pressure 235.
