7 members (Steelonsteel, Otto Skorzeny, Robert Crandall, Charles in CA, JW51, mick53, Gdads51), 128 guests, and 0 robots.
Topics128,109
Posts1,056,267
Members48,439
#677238 09/12/2010 3:49 AM
MY TRUCK SAT FOR A YEAR AND LAST SUMMER I GOT IT GOING BUT IT WOULD BACKFIRE AND RUN ROUGH WHEN YOU STARTED TO DRIVE IT . I REBUILT THE CARB , NEW WIRES , POINTS , CONDENSER AND CAP . CHECKED THE WIRING AND ADJUSTED TIMING AND CARD IN EVERY WAY . ANY SUGGESTIONS
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
SORRY MY TRUCK IS A 1954 GMC WITH A 235 6 CYLINDER
"The Journey"
Follow in the DITY
If you have stale gas in it, that will cause the valves to stick and it will backfire. Get rid of all of the old gas and put something like Marvel Mystery oil in it and try it again.
THE GAS WAS DRAINED AND FRESH GAS PUT IN . THE ENGINE WAS REBUILT YEARS AGO BUT HAS ALWAYS HAD THE OIL CHANGED ONLY HAS ABOUT 7000 MILES ON REBUILD . OIL HAS NOT BEEN CHANGED RECENTLY BUT AS I THOUGHT I WOULD GET IT RUNNING PROPELY FIRST. OR SHOULD I CHANGE THE OIL? I ALSO WAS THINKING OF TAKING THE MUFFLER OFF TO CHECK FOR IT BEING PLUGGED BUT THE TRUCK IDELS NICE.
"The Journey"
Follow in the DITY
If your truck is "BACKFIRING" that means that ignition is occurring in one or more combustion chambers while an intake valve is either open or not sealing. This could be due to early timing, a sticking valve ("open" weak valve spring?), improper valve adjustment or a defective valve to valve seat seal (bent valve or scored valve face or seat).
Best Regards
Will
