| | | Forums66 Topics128,078 Posts1,055,940 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#67650 10/24/2006 4:48 PM | Joined: Oct 2006 Posts: 63 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 63 | Hi --- first off, thanks for this forum. I just bought a '51 AD 3/4 --- complete but hasn't run in years. I worked on cars a little in high school and grew up in my Dad's machine shop, and have been reading the rebuilding manuals, but I'm a novice. Before I completely rebuild carb I wanted to see if she'll start, so couple of questions. I'm replacing coil, points, plugs, oil, and fixing some wiring. I removed carb --- is it advisable to soak the carb in mineral spirits at this stage, just for a general cleaning? It's the Rochester B. Where the throttle post meets the linkage piece, it seems a little loose (not spinning, just wiggly). Seems to me that the original weld may have worn --- can that be re-welded? I was told I should put thin oil in and just crank and crank it with a 12 volt battery to "limber up the engine" then run gas off a can and start it with the 6 volt. Is this 12 volt thing advisable? Also, I need to do some rewiring --- is there a standard guage I can use for the ignition system? Thanks, | | |
#67651 10/24/2006 4:57 PM | Joined: Jan 2005 Posts: 164 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 164 | Short answer...you can start it off 12 volts for a little while, but I wouldn't do it for a long time.
The starter should be fine, but your lights and gauges could fry. If I understand, and you're just trying to "loosen it up" with 12 volts, I'd recommend unhooking the electrical system...except for the starter. | | |
#67652 10/24/2006 6:35 PM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Colorado51, Welcome to the Stovebolt. I agree with CanyonAg77, if you are just going to spin and loosen, jump right to the starter with your 12 volts and bypass regulators, generators etc. I think your loose linkage piece is staked to the throttle shaft. If you are careful, it could be brazed or silver soldered tight. Giving the carburetor a bath in paint thinner won't do any harm, but will probably be for esthetics only. Before you do your 'spin thing' shoot some quality oil into each plug hole, and even down the intake manifold. Great idea on bypassing the factory fuel tank for the initial blast off. Almost all the wires on your rig will be in the 14/16 gauge size. This would be adequate for any ignition load. If you scout around, you will see larger wires that carry charging loads leading from things like the generator, and going from regulator to ammeter. These could be as large as 10 gauge because they carry the system load. Be sure to keep a fire extinguisher near by for the maiden voyage...no backfire barbecues! Good luck and keep us posted on your progress. Stuart | | |
#67653 10/24/2006 9:21 PM | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | To add my 2 cents, remove the spark plugs to make the load on the starter less and don't run the 6V starter on 12 volts for too long at a time. If it were me, I'd do 10-15 seconds then let it cool a bit.
#67654 10/24/2006 10:38 PM | Joined: Mar 2006 Posts: 319 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 319 | Welcome to the Bolt, John. I don't have specific answers to your questions but found a couple of resources that you may decide to refer to from time to time. An online 48'-51' chevy truck manual (has the wiring diagram with wire sizes and wire colors) http://chevy.tocmp.com/1948_51truckshop/index.htm A service bulletin from 51' on the Rochester B. http://chevy.tocmp.com/Rochester/index.htm Both of these are from the Old Online Chevy Manual site. Lots of wonderful info there.
"Nothing astonishes men so much as common sense and plain dealing." - Ralph Waldo Emerson
#67655 10/25/2006 7:25 PM | Joined: Jul 2006 Posts: 707 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 707 | Epic #1 got a 12V alternator and system, but I left the 6V starter in there until it broke, which it never did in about 5 years of daily driving. 1951 3800 Be the change you want to see. -hotshoe
#67656 10/26/2006 6:45 AM | Joined: Mar 2005 Posts: 637 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 637 | My good friend had a starter and generator rebuilding business for about 10 years, he said absolutely no problem to use 12 volts on a 6 volt starter, in fact when you buy a "Heavy duty" starter from the factory all they do is put a 6 volt armature in with 12 volt field coils - works like a charm. | | |
#67657 10/26/2006 6:00 PM | Joined: Oct 2006 Posts: 63 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 63 | You guys are great! --- thanks for the words of wisdom. It snowed last night in Colorado, so I'll wait for the warm up tomorrow, then let's see what happens... | | |
#67658 10/26/2006 6:14 PM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Colorado51, Remember that all these "affirmatives" on using the 6 volt starter on 12 volts are for the starter only. Some of the other components are 6 volt only, and will go on permanent vacation if you stick your 12 volt battery in a go for a ride! Stuart | | |
#67659 10/26/2006 6:45 PM | Joined: Oct 2006 Posts: 63 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 63 | Stuart, Yes, I plan to disconnect other systems from the starter and jump the 12 to the starter only to limber up the engine. After I get the carb cleaned and new gaskets and oil changed I'll use a 6 v. One thing seems odd --- I have the foot starter pedal as well as a push button starter on the dash. This doesn't seem right according to the operator's manual --- it's either / or, right? Looks like some hot wire rigging was done to circumvent the ignition switch, for which I have no key. That'll get rewired down the road... | | |
#67660 10/26/2006 7:10 PM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | John,
The notorious 'previous owners' do strange things sometimes. The mystery switch would certainly merit further investigation though.
If it is a momentary switch, it couldn't replace the key switch. You have looked at the starter and it doesn't have a solenoid..right.
This rig has a standard transmission in it I assume. The Hydramatic rigs used a solenoid actuated starter with the pushbutton on the left of the steering wheel, mid dash. They wouldn't have a stomper though.
Stuart | | |
#67661 10/27/2006 1:41 AM | Joined: Oct 2006 Posts: 63 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 63 | Stuart, Mystery switch and key problem solved. The push button seems to have been installed to operate the horn. And get this --- the key from my '63 chevy 3/4 ton fit the '51 ignition switch! | | |
#67662 10/27/2006 2:03 AM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | John, Good work! You have a horn and a key, what else could a person ask for. Stuart | | |
