15 members (Otto Skorzeny, Jims46, Hawkman, Southerntruck, J Lucas, D B Cooper, Oldcaliforniakid, Stovebolt48, Bill Hanlon, Peggy M, DadsFirstPickup, Ponchogl, Hotrod Lincoln, 32Fordpuchoptop, 1 invisible),
92
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,049 Posts1,055,674 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2008 Posts: 64 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2008 Posts: 64 | I changed my ball bearings out for roller bearings,I put the new races in the hub and then the inner bearing and seal ,then the dust cover .Then tried to put it on the spindle, but it does not want to slide on.I did not use a bunch of force to try and get it to go on the spindle .Is something you need a 2x4 and a good hammer to knock on ,or should it go on easy? Thanks for you help Longhorn | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | You need to dress the spindles down a tad with 400 grit sandpaper. | | | | | Joined: Nov 2008 Posts: 64 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2008 Posts: 64 | Thanks Cletis I got them on there. Longhorn | | | | | Joined: Mar 2010 Posts: 843 Shop Shark | | Shop Shark Joined: Mar 2010 Posts: 843 | It's easy to hammer a bearing onto a shaft or into a blind hole. How will you remove it?
Ray
Ray
| | | | | Joined: Jan 2009 Posts: 101 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2009 Posts: 101 | I also was stumped for a while with the same problem. A mechanic friend told me to use the 400 grit sandpaper and it worked like a charm.
Disciple
