1 members (1 invisible), 56 guests, and 6 robots.
Topics128,014
Posts1,055,324
Members48,419
#67642 10/24/2006 1:41 PM
Apprentice
Apprentice
Hi Guys.
I have arochester Model B Carb. I have just finished rebuildin it. However when i use the float setting chart that was given with the carb float level 1 and 9/32 and float drop 1and 3/4. When i use this setting the carb floads all over the place and into the manifold and even leaks all over the engine. i have increased the float level point to about 1 and 20/32 to try to lower the amount of fuel in the bowl. this sort of worked my car did start but it will only run as long as i press and hold the gas pedal about half way and at that point of time it runs but sputters and has a very rough idle. but as soon as i release the gas the car stalls
#67643 10/24/2006 7:12 PM
I'll guess you mixed up the balls(there's 2 different ones in the kit)or you transposed the spring/ball in the power circuit. Something is not put together properly. Check and see if the air horn isn't warped either. This article pertains to 2 carbs but the pictures might help you get things in the right order. Click on the link then tech tips and then multiple rochesters. Good luck.
http://www.inliners.org/
You Tube
#67644 10/25/2006 5:19 PM
After double checking all the internal parts you still may have to do some creative adjustment on the float. They don't always work according to the specs. I just did one of these carbs on a 56 Car and it would in no way run right with the 1 9/32 setting. It took a couple of attemps at different settings to get it right. Fred
#67645 10/26/2006 6:52 AM
The best way to check float level is remove the carb top, turn it upside down. The top of the float should be just above the flange on the top, turn it over and it should drop about 3/8" to 1/2". Check the float while inverted blow in the gas supply inlet, should not pass air, lift the float and it will pass air. May sound "shade tree" but it works. I have 2 Rochester B carbs on my 248 GMC and they work fine, no leaks at all and it runs good.
#67646 11/04/2006 5:55 PM
Just went through this with my "B" carb - the float had been installed upside down by the previous re-builder. It would work, but only it the level was adjusted beyond specs.
Jeff
