0 members (), 77 guests, and 1 robot.
Topics128,030
Posts1,055,428
Members48,422
#676274 09/07/2010 6:11 PM
1 Offline
guys i need any/all info about the o.d. cable for my 56' chevy 3100 panel with sbc. i have looked at the manual online but some actual pictures would be great and info from somebody actually running one. thanks
Cletis #676339 09/07/2010 9:17 PM
10 Micron, Just read a great article in the July Street Rodder all about overdrives. Lots of pictures and list a company www.vanpeltsales.com for parts etc.
Best of luck
Jim
1946 1/2-Ton Chevy
k10 Offline
Micron, we need a little more information. What are you running for an overdrive. Manual -auto? Borg Warner, Truckstell, 700R4. I have no idea what you need. A PTO cable or a Lokar? Help us help you.
k10 #676530 09/08/2010 11:54 AM
1 Offline
the o.d. is the stock 3spd (R10) BORG-WARNER? the pto style cable.
10 micron #676532 09/08/2010 12:32 PM
ODSS President
ODSS President
Position IN = overdrive capable, Position OUT = Direct Drive, regular three speed. I have my '62 3sp+od connected to a switch so that I can split the gears and have 6 forward gears.
Factory has the kick-down and governor in use which I intend to try some day. There are many sources available for setting up your od in this manner using a $2 relay, $3 push-pull cable, and a $3 kick-down switch from Radio Shack.
~ Cosmo
1949 Chevy Half Ton
Cosmo #676534 09/08/2010 12:47 PM
One precaution- - - - -something like a choke cable won't be sturdy enough to assure good operation of the OD lockout lever. Go to a shop or a parts dealer where they service PTO's, like maybe one specializing in working on dump trucks, etc., and get a heavy-duty push-pull cable assembly. The only time the cable is pulled is when you want to lock the OD out of engagement, like for trailer towing, descending steep hills where you need engine braking, etc. I strongly reccomend doing the whole setup with the relay, kickdown switch, and governor. It works much better if it's installed the way it was designed!
thumbs_up
I used a Chelsea PTO cable for mine. Was somewhere around $35, but well worth the cost for a reliable part.
Bill Burmeister
LONGBOX55 #676932 09/10/2010 10:49 PM
1 Offline
got a link for the PTO CABLE? smile
10 micron #676950 09/10/2010 11:25 PM
micron - search for the closest location, they're common
