3 members (Brian Moore, klhansen, wilbur53), 100 guests, and 2 robots.
Topics128,126
Posts1,056,356
Members48,441
#674816 09/01/2010 11:25 PM
i some how lost (grandkids) a can of pins, springs,
and clips for my 52 3800 drivers side rear..
any body know where i can get these parts..
most websites only carry up to 3/4 ton
these are huck brakes
Did you try Chevs of the 40s? I had some problems with them but they saved themselves.
Check the specs on the missing parts. You may find they are the same as a 3/4-ton depending on exactly what you need. Much of the 3/4- and 1-ton suspension pieces are the same as some of the larger trucks.
Not everything by any means, and I don't recall exactly which pieces will swap but some time in the parts book will clarify that for you. You can find the parts book at Master Parts Book.
Once you have the GM part number, do a web search. I have been pleasently surprised several times on finding odd stuff. There are a lot of NOS dealers that you can connect to only with a web search.
i checked OldSub's link to the chevy master catalog & it appears 3/4 &1 ton huck brakes are the same from 1946 on.
robert
Robert French MY3800FIRETRUCK
thanks, got them at a local junkyard along with a 50 GMC 250
Moderated by  Dusty53
