| | | Forums66 Topics128,051 Posts1,055,764 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2005 Posts: 1,028 'Bolter | | 'Bolter Joined: Sep 2005 Posts: 1,028 | I found a 12 volt alternator...I have heard these called 2 wire alternators but I think this is also referred to as a 1 wire. http://good-times.webshots.com/photo/2808211950083206947leFsmCI believe I can connect the red wire from the DA plug and the red wire on the fastener to the battery and the other DA wire to the ammeter. Then disconnect the voltage regulator and have a 12 volt system. I also need 12 volt light bulbs and resistors in front of my fuel gauge and coil. This is a floor stomp starter. My question is I have a 6v pertronics ignition. If I have a resistor in front of the coil can I keep the flamethrower coil and pertronics ignition set up for my current 6v system or do I need to replace them with 12 volt pertronics set up. Thanks Rich | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Do you have a model number for your alternator? Knowing what size it is might make a difference in wire size as you connect it.
The 1-wire approach requires revving the motor to get the alternator above a certain speed before it begins charging. Using all three wires means the alternator will provide power when it is needed.
I'm not a fan of the 1-wire approach though many others love it.
If you get the resistor wrong you might cook or under power the Pertonix. I'd suggest swapping to the 12-volt version.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Sep 2005 Posts: 1,028 'Bolter | | 'Bolter Joined: Sep 2005 Posts: 1,028 | Old sub. Is there an alternative to the 1 wire approach?
| | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Sure. Wire it the way the factory wired the alternator. While people use a GM alternator as a 1-wire I don't believe GM ever installed it in a car or truck that way. I'm not a big fan of Mad Electrical buy you might find their explanation of 1-wire versus 3- helpful. Mad Electrical. I don't seem to have any wiring diagrams handy or I'd post a link to one.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Sep 2005 Posts: 1,028 'Bolter | | 'Bolter Joined: Sep 2005 Posts: 1,028 | Old sub,
I think I have a three wire and I would like to wire it that way.
Maybe I misunderstand but it looks like the three wire in the link you sent is wired so that one wire from the DA plug on the alternator is connected to the terminal wire on the back of the alternator. That terminal is then connected to the batt terminal from the old voltage regulator. The second wire from the DA plug on the alternator would go to the ignition switch. Is that not a 3 wire configuration?
If I put a light in the line to the ignition would that function as an alt light and light up when not charging?
Thanks Rich
| | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | That sounds right but its been so long since I last did it I'd have to look it up to be sure.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | We use 1 wire on all of our trucks and stationary engines. However they do have 2 terminals. One goes to the battery and the other is grounded to the block or a starter mounting bolt. This is a pretty good discussion about alternators. http://news.prestolite.com/drupaldocs/TSB-1057_Universal_alternator_wiring.pdf | | |
