0 members (),
73
Mod | | | Forums66 Topics128,093 Posts1,056,474 Members48,444 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#67606 10/23/2006 2:39 AM | Joined: Aug 2006 Posts: 40 Member | | Member Joined: Aug 2006 Posts: 40 | 52 3600 runs fine down the road. the aggravating thing is that when you change gear....any gear...as soon as you push in the clutch and let off the gas the motor revs up about 500-1000 rpm for a couple of seconds before it backs down. the manual choke works fine and is not sticking, there is no heat riser. is this an internal carb problem or a vacuum problem? Thanks, Dash Riprocker | | |
#67607 10/23/2006 3:42 AM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Dash Riprocker,
My first thought would be a vacuum leak in the system. Under high vacuum, as when the throttle closes, air is entering the system and causing the engine to speed up for a moment.
The power valve in the carburetor reacts to this change, but in reverse to what you are seeing.
The vacuum advance is also on this circuit, but should not see this high vacuum if the throttle plate is closed.
I would check the vacuum advance diaphragm for leaks, and would make sure the carburetor base gasket is good.
If you poked around with the engine running at a idle, and shot carb cleaner in suspicious places, you might find a leak.
Sticking throttle linkage could be a possibility, but I'm sure you have checked that, right!
Stuart | | |
#67608 10/23/2006 3:57 AM | Joined: Mar 2005 Posts: 1,029 Member | | Member Joined: Mar 2005 Posts: 1,029 | You don't have a dashpot that keeps the throttle from backing off too fast, do you? These were installed on carburetors for smog purposes. | | |
#67609 10/23/2006 4:34 AM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | I wonder if a loose or broken motor mount could be causing the linkage between pedal and engine to be tweaking which might cause a momentary increase in RPM?
Stuart | | |
