2 members (klhansen, 2-Ton),
85
Mod | | | Forums66 Topics128,037 Posts1,055,465 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2010 Posts: 109 Shop Shark | | Shop Shark Joined: Aug 2010 Posts: 109 | I finally got the trans working right and the leak stopped on the C-10. Now we've got brake problems, the day we tried out the repaired trans, the front brakes started tightening up. They got tight enough that it was hard to pull itself. We stopped for a few minutes and they loosened up enough to drive on home. Now the pedal goes to the floor and only the rears work. There is very little fluid at the caliper bleeder when the pedal is pushed. I tried to reverse bleed with a big syringe and couldn't get fluid to go to the MC. I took the line loose at the MC and easily pushed fluid back up to it. I'm thinking something is blocked in the master restricting the flow. Does that sound logical?
'65 C-10, 65 L-60, 65 C-80, 72 C-60 & and a bunch of old Chevy cars. Never time to do it right, always time to do it over.
| | | | | Joined: Sep 2006 Posts: 841 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 841 | if it's been sitting a while the lines might have sludge/ contamination in them. if it's a loooong time the fluid turns to a white chalk. when i start driving a "field special" i take each line loose and clean the lines with alcohol and compressed air. then rebuild each wheel cly. i noticed you mentioned caliper have you changed the front brakes over to disc brakes? if soit might have something to do with that, if it's been recently changed. good luck | | | | | Joined: Aug 2010 Posts: 109 Shop Shark | | Shop Shark Joined: Aug 2010 Posts: 109 | It's all new stuff. The front end is out of a 72 C-10 with a CPP brake kit with 6 lug discs. It has a 8" booster with Corvette master cyl. and all new lines. I have a brake control valve in the rear line.
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Your pushrod between the MC & the booster is probably too long holding the master cyl on a little. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Aug 2010 Posts: 109 Shop Shark | | Shop Shark Joined: Aug 2010 Posts: 109 | I think it was when they locked up. I shortened it 1/2" this morning and got the pedal free play about right. Now I just can't get front brakes.
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Mearl, did you install a combination valve with your new master cylinder? It sounds like the valve may have shuttled over shutting off flow to the front brakes. If you can generate any pressure in the front brakes, you could slowly open a rear brake bleed screw, this would mean less pressure in the rear system than the front system, and the valve should shuttle towards the center if not all the way to the rear, you may have to chase it back and forth before you get it in the center. Once you think it is in the center close all the bleeders tightly and slowly step on the brake pedal to generate pressure, this should finally center the valve, hope that helps | | | | | Joined: Aug 2010 Posts: 109 Shop Shark | | Shop Shark Joined: Aug 2010 Posts: 109 | I didn't use a combination valve, just the adjustable valve to the rear wheels. I thought that would be enough. Now when the pedal is pushed down, I can see the calipers move just a tiny bit at the very bottom of the pedal travel.
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Mearl, I think you should remove the lines from the master cylinder and bleed the master cylinder alone. Do you have the primary system [closest to the firewall] activating the front brakes? | | | | | Joined: Aug 2010 Posts: 109 Shop Shark | | Shop Shark Joined: Aug 2010 Posts: 109 | I have the front chamber going to the front brakes. That's the way I thought they were supposed to be. I was going to bleed the master with the lines off but I couldn't find my bench bleed fittings.
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Mearl, the primary system [closest to the fire wall] should be plumbed to the front brakes. As you are using a master cylinder designed for a vehicle with disc brakes all around, I would suggest a 10 p.s.i. residual pressure valve be installed in the rear brake system, as a minimum addition to what you have already done. I highly recommend a combination valve for a disc drum system be installed, this would give you the metering function your adjustable proportioning valve is now doing, and if you hooked up the warning light circuit, it would provide you with a visual signal of system problems. Hope that helps. | | | | | Joined: Aug 2010 Posts: 109 Shop Shark | | Shop Shark Joined: Aug 2010 Posts: 109 | I looked at a couple of my old cars, Trans Ams & a 69 El Camino, they all have the larger chamber which is the front, going to the front brakes. Of course they also have proportioning valves. I thought since both chambers are the same size on the Vette cylinder, it wouldn't make any difference. That's why I put the adjustable valve on the rear. Another thing I may have screwed up is putting big lines on the front and small on the rear, would that be backwards? I was thinking that the calipers needed more fluid. If you still think I need to swap the chambers, I'll try that this weekend.
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Mearl, because the master cylinder you're using was designed for a disc/disc application, both chambers would be close to the same volume, if not identical. Wherever possible I try to copy factory engineering, the only exception to that would be to make something bigger/stronger, so I would use the same size lines as the factory used. I still think you should bleed the master cylinder alone, before you attempt anything else. Once we went to disc/drum vehicles, you are correct the larger volume cylinder was used for the front brakes, on the drum/drum master cylinders the primary system activates the front brakes. I think you may have some air trapped in the master cylinder. I still recommend the installation of a combination valve, but that is ultimately your choice, good luck, and let us know how it goes. | | | | | Joined: Aug 2010 Posts: 109 Shop Shark | | Shop Shark Joined: Aug 2010 Posts: 109 | I took the master cylinder off and bled it on the vise. The rear worked as it should and pushed a strong stream of fluid when I held it out of the chamber while pushing. The front didn't do any thing, no bubbles or fluid.
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Mearl, it sounds like you have a failed seal in the secondary side of your master cylinder. I would send it back as a failed new part, and get them to send you another one. | | | | | Joined: Aug 2010 Posts: 109 Shop Shark | | Shop Shark Joined: Aug 2010 Posts: 109 | I'm glad to finally get it narrowed down, finding the time during the week is the hard part. I can't send it back, I've had it a couple of years and it did work. I don't mind buying another one. 3B thanks for all your help on this one, it would be nice if this thread helps someone else.
| | | | | Joined: Aug 2010 Posts: 109 Shop Shark | | Shop Shark Joined: Aug 2010 Posts: 109 | Good news on the 65 C-10 brakes. We replaced the defective Vette master cylinder with a reman one from the auto parts. This one is for a 71-early 80's chevy pickup. The primary chamber is the rear one and is larger than the front. I switched the lines around to fit it and put it on after bench bleeding. We had a good pedal before we even bled the brakes! Now they are exactly as they should be. I think I learned some lessons here. I don't think a Corvette cylinder is the best idea for disc/drum because there is no primary chamber due to the 4 wheel discs. Anyway Deb got to drive her truck again and now I can get to one of my projects. I just wish she'd finish the bodywork on the tailgate.
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Mearl, that is great news, which I'm glad to see/hear, continued good luck. | | | | | Joined: Oct 2008 Posts: 67 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2008 Posts: 67 | sounds like no freeplay in the pedal linkage to me, pedal should move at least 1/8 inch before it does anything.. | | |
