4 members (Gdads51, mick53, KEVINSKI, FAST55), 87 guests, and 2 robots.
Topics128,090
Posts1,056,018
Members48,430
#675788 09/06/2010 12:33 AM
I'm doing some research on the pros and cons of bypassing my carrier bearing and replacing my 2 piece driveline with 1 section about 8' long. This is in a 1 ton show truck. Any thoughts?
Really bad idea, if it is ever going to go on the road. If all you ever do is load it on and off a trailer, maybe, but 8 feet is waaaaayyyy too long to be reilable at road speed.
Check the tech tips tab at the top of the page for driveline setup.
Stick with the two piece, the info in the tech tip will explain why a single long shaft is a terrible idea.
1952 Chevrolet 3800 pickup
---All pictures---
No reputable drive shaft shop would build an 8' drive shaft. The center bearing is there for a reason.
Thanks for the info. It looks like I will need to come up with roughly 2 and 1/4 inches to the rear driveline for the system to work.
