| | | Forums66 Topics128,078 Posts1,055,936 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 323 Shop Shark | | Shop Shark Joined: May 2005 Posts: 323 | I'm doing some research on the pros and cons of bypassing my carrier bearing and replacing my 2 piece driveline with 1 section about 8' long. This is in a 1 ton show truck. Any thoughts? | | | | | Joined: Feb 2004 Posts: 29,780 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,780 | Really bad idea, if it is ever going to go on the road. If all you ever do is load it on and off a trailer, maybe, but 8 feet is waaaaayyyy too long to be reilable at road speed. Jerry
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Check the tech tips tab at the top of the page for driveline setup.
Stick with the two piece, the info in the tech tip will explain why a single long shaft is a terrible idea. | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | No reputable drive shaft shop would build an 8' drive shaft. The center bearing is there for a reason. | | | | | Joined: May 2005 Posts: 323 Shop Shark | | Shop Shark Joined: May 2005 Posts: 323 | Thanks for the info. It looks like I will need to come up with roughly 2 and 1/4 inches to the rear driveline for the system to work. | | |
