4 members (ndkid275, 2-Ton, Shaffer's1950, Otto Skorzeny), 159 guests, and 1 robot.
Topics128,048
Posts1,055,539
Members48,424
Ok, I was just wondering if there was a trick to sealing the temparature sending unit doo-dad(original)in the head. It's on a 49, with a 216. Teflon tape? anything else?
oldcarandtrucknut,
I think that doo-dad seals mechanically...no dope needed. As I remember, the adapter bushing , which is a pipe taper and might seal better with pipe sealant, threads into the head.
The sensing bulb sits inside this, and is sealed on a small shoulder as the second nut is tightened.
The second nut, (square nut?) mechanically seals the bulb in the adapter fitting...hope this is right! grin
Stuart
I used Permatex #2 sealant. Works very well.
Bill Burmeister
Should the temperature sending unit on a 216 head need a bushing? Doesn't that sender just bolt/screw right into the head (it's been a while since I've seen a 216 head)?
Tim,
It's been a mere 44 years since I played with that item. Your probably right on the money...I do remember a weird square headed fitting that screws into the head and holds the bulb in though...I think!
Stuart
Yes Stuart, that is a square headed fitting and it does thread directly into the head. There is no 2nd fitting. What you said about sealing mechanically is right, looks like the fitting sandwiches a little flange on the temp. "bulb" between it and the head. What I'm concerned about is how old these pieces are- they probably are not completely smooth, so a leak may occur. So, maybe some of that permatex sealant on that flange would work?
The bulb and fitting is bronze and self-crushes to fit.
You can screw a 216 style temp sender into a 235 head with a 1/2 NPT to 3/8 female gas flare adaptor- the early sender uses a gas flare taper and threads, not pipe threads. The 235 sender uses 1/2" pipe threads.
Paint & Body Shop moderator
