| | | Forums66 Topics128,049 Posts1,055,552 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#67573 10/22/2006 1:15 AM | Joined: Dec 2005 Posts: 62 Member | | Member Joined: Dec 2005 Posts: 62 | Hi Folks,
This has probably been asked before, but what axle assemblies will work to replace the one in a 41 3/4 ton truck? I would like to have a higher gear ratio than 4.55:1.
Jeff | | |
#67574 10/22/2006 2:14 AM | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | A 1941 3/4 ton should be six lug and open drive line originally. A 1955-62 1/2 ton center section will fit right in using the original axle housing and uses the same axle splines also. Most 55-62s will have a 3.9 ratio. There is a new 3.38 gear set available. You will need to adapt the drive line to the 1/2 ton U-joint.
See the USA in your vintage Chevrolet! My Blog | | |
#67575 10/22/2006 4:07 PM | Joined: Dec 2005 Posts: 62 Member | | Member Joined: Dec 2005 Posts: 62 | Is adapting the drive line to the 1/2 ton U-joint difficult. In fact, how difficult is changing the center section? Where can I find the new 3.38 gear set?
Jeff | | |
#67576 10/23/2006 12:38 AM | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | There are conversion U-joints made for some of these conversions, I would need to check the 41 joint size. I think I would have the rear yoke on the drive shaft changed if I were doing the conversion. Changing the center section is quite easy. Patrick's carries the 3.38 gears. www.patricksantiquecars.com 520-836-1117
#67577 10/24/2006 8:51 PM | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | http://www.stovebolt.com/bboard/cgi-bin//ultimatebb.cgi?ubb=get_topic;f=2;t=011805;p=1#000013
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
