0 members (),
62
Mod | | | Forums66 Topics128,009 Posts1,055,293 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2004 Posts: 91 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2004 Posts: 91 | I've got a '51 3100 with a 235 out of a '57. Somehow part of the throttle linkage has been lost. I've got the bell crank that goes on the block(pretty worn) and I've got a curved peice that goes from the bellcrank to the carb, a small hole drilled in one end. Does anyone have the correct throttle linkage that they would be willing to part with or have a pix in their album showing the complete linkage. I'd really appreciate help on this one. Plus, could anyony show pictures of their firewall. This would help too. Thanks | | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | If You look thru My pic's on photo bucket You can see my firewall and there are some pic's of the carb linkage also.
Pete | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | I may be wrong, but I think the "curved piece" you are referring to actually connects to the accelerator peddle with a pin that passes through the hole you see and is held in place by a cotter pin. The other end should have a 90 degree bend in it that goes through the top hole of the bellcrank and is held by a washer and cotter pin. However, because you have a later engine than the cab/chassis, other modifications of the linkage may be required to make it work smoothly.
Drew
| | | | | Joined: Dec 2004 Posts: 91 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2004 Posts: 91 | Thanks Pete and Drew; I could not find a pix of the linkage but I may not have searched them all.. Drew, I don't think the curved one goes to the pedel, as a matter of fact , I don't really know where it goes. The reason I am baffled is that one guy took the engine out to rebuild and I put it back in. I think he lost a part or two. Hopefully someone will have the linkage and is willing to part with it. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I did not not look through all 250 or so photos in Pete's interesting albums, but maybe he is referring to this photo ? If that is not the best photo, maybe Pete will post a link to the specific photo? | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | Elmer,can you post a picture of what you do have ? 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Dec 2004 Posts: 91 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2004 Posts: 91 | Elmer,can you post a pi
cture of what you do have ? Yes, I will try and do that tommorow. | | | | | Joined: Dec 2004 Posts: 91 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2004 Posts: 91 | I'm having trouble posting pictures, computer illiterate. I created an account on Photo bucket and have 2 pics in an album, but cannot move them to Stovebolt. Any ideas????? | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | | | | | | Joined: Dec 2004 Posts: 91 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2004 Posts: 91 | | | | | | Joined: Dec 2004 Posts: 91 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2004 Posts: 91 | Hey Bowtietim, I can't figure out the pic posting process on this site. I can email you a few pics if you send me your email address in a pm. That's about all I can do at this time. Thanks | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | This is a picture of elmers linkage.The bent curved one looks like it is the bell crank to throttle linkage . I'm a little confused on the shape of it,can you guys step in and help elmer out. elmers linkage Thanks,Tim 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Apr 2005 Posts: 2,097 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,097 | The bellcrank looks something like the trans shifter linkage that pivots on the 6 cyl bellhousing. The other rod could be a bent up shift rod from some unknown application. Fred
| | | | | Joined: Sep 2008 Posts: 137 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2008 Posts: 137 | The rod going from the bell-crank to the carb on our truck doesn't have near that much bend in it. Not to say that it wouldn't work, but it looks pretty odd. I think ours goes up through the gap between the manifold and the block. That one looks like it's curved enough to go out around the outside of the manifold. Seems like it would bind that way, but who knows. | | | | | Joined: Dec 2004 Posts: 91 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2004 Posts: 91 | Well, I am back to square one again. There was a linkage on Ebay advertised as a '56. I bought it and got it today, not the right one. Does anyone know where I could look for one????? Thanks | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | here's a hint of what you need from a recent thread, not real clear but from a 57 .... put a post in the parts wanted, and while any year 235 linkage should work at the engine, the piece from that bellcrank to the pedal might need to be for your year Bill | | |
