7 members (FAST55, TUTS 59, Wally / Montana, Wickedbass, Mike Burns, Gdads51, Donf),
85
Mod | | | Forums66 Topics128,065 Posts1,055,870 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2010 Posts: 32 Apprentice | | Apprentice Joined: Aug 2010 Posts: 32 | I'm doing a resto on a 52 6500 2 ton. I'm pretty sure the brake booster doesn't work because someone back in the day tried to bypass it. What are the odds I'll be able to rebuild that or find a working one? What are the odds that the rear end works and if it doesn't what are the odds I can make it work?
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy 52FamrME, welcome, kits are available to rebuild the hydrovac, and some places offer a rebuild service, also straight purchase with yours for a rebuildable core may be possible. As to the rear axle you'll have to open it up and do an inspection. What makes you think the rear axle is bad? | | | | | Joined: Sep 2006 Posts: 1,997 Big Bolt Forum Co-moderator | | Big Bolt Forum Co-moderator Joined: Sep 2006 Posts: 1,997 | Check the Jim Carter catalog for a hydrovac: http://www.oldchevytrucks.biz/47_55/full.asp?page=81Check the end cap where the J-bolts attach and make sure it hasn't deteriorated beyond repair. A day without laughter is a day wasted- Charlie Chaplin When wrestling a grizzly bear, you have to keep at it until the bear gets tired, not when you get tired. 1948 Chevy 2-Ton | | | | | Joined: Aug 2010 Posts: 32 Apprentice | | Apprentice Joined: Aug 2010 Posts: 32 | Where are you talking about on the system for this end cap and J bolts.
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy 52FamrME, Super55 is reffering to the aluminum cap which fits on the vacuum chamber of the hydrovac, it is on the end that the hydraulic lines go into. The end is held in place by four "J" bolts which pass through four holes or ears in the aluminum end cap, because the bolts are steel and the cap is made of aluminum the parts are often locked together by corrosion. In order for your core to be accepted the parts must not be broken, hope that helps. | | | | | Joined: Aug 2010 Posts: 32 Apprentice | | Apprentice Joined: Aug 2010 Posts: 32 | thanks...aahh differential metal corrosion. | | | | | Joined: Feb 2007 Posts: 190 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 190 | Hydrovac can be rebuilt like as been said. Hopefully check the oil in the rearend and go, their mighty tuff. My trucks hydrovac was rebuilt and I was surprised at how good it works. Best brakes I have ever had on an antique, good luck with yours. | | | | | Joined: Aug 2010 Posts: 32 Apprentice | | Apprentice Joined: Aug 2010 Posts: 32 | Thanks I've heard that these brakes work great if maintained. | | | | | Joined: Feb 2004 Posts: 29,776 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,776 | The only problem with a hydrovac is that it can't be used as a split system. If you want the added safety of a dual-chamber master cylinder setup, you'll need to go to another type of M/C-booster system. Jerry
