0 members (), 46 guests, and 3 robots.
Topics128,014
Posts1,055,327
Members48,419
#492242 01/12/2009 1:23 AM
Apprentice
Apprentice
i am trying to get the 216 running in a 39 frame i just bought. there is no wiring except for the positive cable from the starter and the wire going from the coil to the distributor. anyone know how i can get it simply wired to see if she will start.
david
If at first you don't succede, try try again. Then quit, don't be a darn fool about it.
get a length of wire with a couple alligator clip on each end. Hook one end to the + side of the coil and the other end to the battery + post. You should also make sure that you have a negative cable from the battery - post to the engine block. This should be enough to see if its going to run. If it starts and you want to shut it off just take the alligator clip off the battery + post.
jdl Offline
Yep, and if it doesn't, start checking to see if the points in the distributor "spark" when you turn the engine over by hand(DISCONNECT the BIG COIL WIRE coming out of the top so that it doesn't fire and accidentally start when you are doing this). If it doesn't, replace the points/condenser. If it does, then the coil is bad or the sparkplug wires are bad. Another, quicker way to do this is simply to disconnect the big coil wire coming out of the top of the coil from the distributor and hold it really close to the engine to see if it arcs.
Jordan D. Long
1954 Chevrolet 3100 1/2-Ton
And some more pictures
Photobucket
I got a 'Possum Pickup... Now I'm the Roadkill King!!! Anyone want to make some Stovebolt Stew?
jdl #492658 01/13/2009 2:28 AM
Apprentice
Apprentice
thanks. i got it started and she runs like a champ.
To resurrect an old topic....i've done the above and i'm not getting any spark from the coil wire when i hold it near the engine. This is a new coil; is there any way to test it? 41 1/2 ton with 54 325, 12v upgrade. Thanks.
watsjoe #675033 09/02/2010 6:53 PM
The coil wire will not spark. try one of the plug wires.
1953 Chevrolet 3600
Fried Green T'mater (Vern)
Caution: Political Statement
