8 members (Hotrod Lincoln, MickeyP, Peggy M, 55shaker, klhansen, Craig /49 Panel, Shaffer's1950, Otto Skorzeny),
69
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,132 Posts1,056,386 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2009 Posts: 2 New Guy | | New Guy Joined: Jul 2009 Posts: 2 | i some how lost (grandkids) a can of pins, springs, and clips for my 52 3800 drivers side rear.. any body know where i can get these parts.. most websites only carry up to 3/4 ton these are huck brakes
| | | | | Joined: Aug 2010 Posts: 38 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2010 Posts: 38 | Did you try Chevs of the 40s? I had some problems with them but they saved themselves. | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Check the specs on the missing parts. You may find they are the same as a 3/4-ton depending on exactly what you need. Much of the 3/4- and 1-ton suspension pieces are the same as some of the larger trucks. Not everything by any means, and I don't recall exactly which pieces will swap but some time in the parts book will clarify that for you. You can find the parts book at Master Parts Book.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Aug 2010 Posts: 38 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2010 Posts: 38 | Once you have the GM part number, do a web search. I have been pleasently surprised several times on finding odd stuff. There are a lot of NOS dealers that you can connect to only with a web search. | | | | | Joined: Mar 2005 Posts: 171 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 171 | i checked OldSub's link to the chevy master catalog & it appears 3/4 &1 ton huck brakes are the same from 1946 on. robert | | | | | Joined: Jul 2009 Posts: 2 New Guy | | New Guy Joined: Jul 2009 Posts: 2 | thanks, got them at a local junkyard along with a 50 GMC 250 | | |
