3 members (1955 1 Series, Bill Hanlon, 1 invisible), 326 guests, and 3 robots.
Topics128,156
Posts1,057,021
Members48,460
For some unknown reason I never get a long life out of my foot starter...
I want to simplify things & convert to a solenoid starter.
I bought a 55/56 solenoid starter from JIM CARTER.
After getting it I'm wondering if I should have gone with a 57 or later starter(better design?). I haven't installed her yet & can return it
if the 57s are more reliable.
Also don't know how to wire it. Connections are "S" & "R". I'm thinking that a ground push button on the "s" will work???
Riding in the Passing Lane
If you are going to use a key turn ign. switch run a 12 gauge purple wire from the starter term to the S term on the selinoid. If you are going to use a push button switch run that same wire to one term on the switch & the other term to a hot bat connection. You should have a small wire on the side of the switch on the stomp starter. Connect that to the R term.of the selinoid. It bypasses the resister for more voltage to the coil when cranking. The other end should be connected to the pos. side of the coil.
I don't know which starter is best, but the later model is easier to work on.
1972 Chevy c10 Cheyenne Super
