| | | Forums66 Topics128,052 Posts1,055,719 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | LCT, It may be easier and cheaper to have the right side ell brackets and arm made and then buy two matching mirror heads. The mirror head you have now doesn't look original, it look to big. Before going to the trouble of making a right side bracket and arm you might want to confirm the support bracket with the captured nuts is installed inside the door. Take the door panel off to confirm it's there. If it's there you can take a centering punch and put it through the nuts and give the punch a light tap to mark where to drill the holes from the outside. Take care! Mike B  | | | | | Joined: Feb 2007 Posts: 195 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 195 | Our 58 spartan came with only one mirror on the left side. It was round and five inches in diameter. My Son made a bracket for the right side(the support bracket with captured nuta was there)made two stainless steel arms and we bought larger mirrors.
Red meat is not bad for you.........Fuzzy green meat is bad for you!
"What happens in the garage stays in the garage!"
1958 Chevy Spartan 100 firetruck in the Gallery
| | | | | Joined: Jun 2010 Posts: 384 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 384 | Our 58 spartan came with only one mirror on the left side. It was round and five inches in diameter. My Son made a bracket for the right side(the support bracket with captured nuta was there)made two stainless steel arms and we bought larger mirrors. Yeah that's an idea of course. To replace the existing one, and add one on the other one..  My Chevy Viking 1959Ulf Hedlund. Eskilstuna. Sweden [email protected]Also: Ford Galaxie 4 dr 1959 Ford Custom 4 dr 1964 Ford Mustang GT 2005
