1 members (Hotrod Lincoln),
49
Mod | | | Forums66 Topics128,021 Posts1,055,355 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2010 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2010 Posts: 46 | Looks fairly straight forward to do on a 1958 fleetside. 4 bolts and unhooking the wiring. Is it that simple? How heavy is the bed? Can two people lift it off the frame, or do I need more? I did some searching on this site, but could not find the info needed. Thanks!
1958 Apache Shortbed Fleetside
| | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | if yer both hulks might find it a little easier with 4, especially if the wood is still in, it does need to be lifted high for the skirts to clear the frame and tires .... and it seems to me theres more than 4 bolts on a short bed, like maybe 4 each side, the 2 on each cross sill and 2 each on the front and rear sills Bill | | | | | Joined: Aug 2010 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2010 Posts: 46 | if yer both hulks might find it a little easier with 4, especially if the wood is still in, it does need to be lifted high for the skirts to clear the frame and tires .... and it seems to me theres more than 4 bolts on a short bed, like maybe 4 each side, the 2 on each cross sill and 2 each on the front and rear sills Bill Thanks Bill. I'll use more people.
