6 members (sron48, MickeyP, Otto Skorzeny, mick53, Gdads51, Jaison), 105 guests, and 2 robots.
Topics128,050
Posts1,055,704
#674202 08/30/2010 8:51 PM
Can you block off the vacume outlets on a pump with the built in vacume pump ? I blocked off the ones on my 53 235 and now the pump will not work ?
And if you open them up again does it work? If so then you have your asnwer...
I expect you can't block them.
If you don't need the vacuum part why not swap for a normal fuel pump?
Grigg
1952 Chevrolet 3800 pickup
---All pictures---
Have a 6v electric pump for wipers, pump is original with glass bowl filter attatched, like to keep as much as GM installed at factory.....thanks...gmguy
I thought that the dual action pump was an option, and if you won't be using it then what's the point?
Personally I'd simplify to a plain fuel pump with the glass bowl on top, or keep the dual action pump and use it for vacuum as designed.
Grigg
---All pictures---
A vacuum boost pump is designed to assist the manifold vacuum, not be used instead of it. I've seen people install a jumper line between the ports instead of blocking them off, and run like normal if they want to disable the vacuum boost. I suspect the problem with blocking the flow is that a vacuum is being formed which keeps the fuel section of the pump from working right. Either leave the ports unblocked, or install short sections of vacuum line and hide the open ends around behind the engine or something.
Thanks for the info on the pump !
