0 members (),
133
Mod | | | Forums66 Topics128,157 Posts1,056,876 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2009 Posts: 25 Apprentice | | Apprentice Joined: Jan 2009 Posts: 25 | does anyone know if I can use my original speedometer and cluster guages with a 12 volt system? If so what do I need to do to make it work? I really want to keep my old guages thanks | | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | You'll find that the gas gauge is the only one to worry about. The AMP gauge doesn't care if it is 6v or 12v, and will work exactly the same on either. Temp is mechanical, oil is mechanical and the light bulb replacements can be had from the parts store or radio shack. I ran a voltage reducer (Runtz, probably did not need it), on my gas gauge until the gauge went bad. You need to make sure the sending unit in the tank has the same ohm range as your gauge. Not a problem if you are using the original tank and sending unit. I've been told that the gas gauge will work on 12V, but I have not tried it and makes it makes no difference to me now that it is broken. | | | | | Joined: Jan 2009 Posts: 25 Apprentice | | Apprentice Joined: Jan 2009 Posts: 25 | Thanks T'mater, what about the speedometer? will that work? | | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | Absolutely. That's a cable that runs to the transmission. | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | My one experience with converting a 6v vehicle to 12v was a LONG time ago when I bought a 55.1 Chevy panel truck. I did the usual changing of the coil & bulbs but I never put a resistor on the gas gauge (never occurred to me that I needed to). In over 100000 miles I put on the truck after the conversion I never had an issue with the gas gauge not working right. It certainly won't hurt if you do put one on the truck and in actuality it's probably a good idea, but my experience is that the world won't end if you don't.
| | | | | Joined: Oct 2008 Posts: 56 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2008 Posts: 56 | I'll give ya'll a little secret I figured out years ago. My first vehicle was a 53 Chev 3100 in 1990.
Here's how you make the gas gauge 100% accurate on 12 volt. Converting to 12V from 6V doesn't require a resistor. IF you don't believe me, remove the fuel sender after you install a resistor in the sender to gauge line. Move the tank sender up and down and it'll be innacurate.
SO, do this. Cut the sender line under the dash. Temporarily install a very small light bulb (like another instrument panel bulb). Operate the sender up and down. You may have to try a few different bulbs until you find one that is 100% accurate. This will work. You will actually notice the bulb will glow a little. It won't fully light up. It's the only thing I found to actually work. Solder the wires to the lightbulb in series with the sender wire when you find one that makes the gauge read E when down and F when up. Reinstall the sender in the tank.
One word of CAUTION. When the gauge reads E, you are not low on gas. YOU ARE OUT!! NO JOKE. Ask my sister. She had to help me push the truck into a gas station. | | |
