| | | Forums66 Topics128,089 Posts1,056,009 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#67377 10/19/2006 4:51 AM | Joined: Oct 2006 Posts: 3 Junior Member | | Junior Member Joined: Oct 2006 Posts: 3 | My son just bought 'another' race car. This time a Chevrolet S-10 with a 350. It has cast aluminum heads with 4 additional bolts per side (21). My brother tells me these heads were off of military powerplants. Any one every heard of this and are they good for performance use? I've drag raced for many years and seen lots of aftermarket heads, they all seem to have some markings, these don't have anything on them. Any help would b appreciated | | |
#67378 10/19/2006 5:00 AM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | I wouldn't expect to find performance heads on any military engine, the military wants reliability and fuel economy over performance.
Did you look under the valve covers for markings?
#67379 10/22/2006 1:24 AM | Joined: Oct 2006 Posts: 3 Junior Member | | Junior Member Joined: Oct 2006 Posts: 3 | We looked under the valve covers and found no markings. We did figure out that the additional bolts are for air injection (smog heads) the bolts are plugging the air injection ports.
The guy we bought the truck from said these are 'Brookfield' heads. | | |
#67380 10/22/2006 3:52 AM | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Wouldn't be military, most military vehicles are deisel powered.
Bill Burmeister | | |
#67381 10/22/2006 11:37 PM | Joined: Apr 2006 Posts: 159 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 159 | How about Canfield ? They make aluminum performance heads.
In the works 2006 GEN III 6.0 /4L80E/ 205 New process,A/C and power brakes .
#67382 10/23/2006 12:09 AM | Joined: Aug 2006 Posts: 59 Member | | Member Joined: Aug 2006 Posts: 59 | 8 more holes drilled into a small-block is not possible . George
1965 C-10 fleetside shortbed BLACK 82 c-10 longbed 6 cyl. 58 Lincoln 2-dr coupe Black w/white & blk. 59 lincoln 4-dr. parts car
#67383 10/23/2006 4:36 AM | Joined: Oct 2006 Posts: 3 Junior Member | | Junior Member Joined: Oct 2006 Posts: 3 | George, we discovered they are air injection ports with bolts put in them to plug the holes.
Longbox55, we used to buy salvage/scrap military parts and indeed had some small block chevy, (even turbocharged) generator engines. I still have a 8-10 quart oil pan for one. | | |
