3 members (Donf, Shof, Peggy M),
131
Mod | | | Forums66 Topics128,281 Posts1,058,488 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2010 Posts: 7 New Guy | | New Guy Joined: Jul 2010 Posts: 7 | My truck (1952 6400 2 ton) has the hydrovac unit. Does anyone know if a power assist brake unit can be used to replace the hydrovac?
PC | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | | | | | | Joined: Jan 2010 Posts: 8 New Guy | | New Guy Joined: Jan 2010 Posts: 8 | What is the power assistbrake unit | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Traditionally they are vacuum boosters bolted to a master cylinder, like most newer cars and pickups have.
Alternatively you can use a hydrobooster as found on most if not all current diesel pickups. If you will have power steering this is my preferred choice by far. A hydrobooster uses PS pump pressure to help instead of vacuum, it is attached to the MC in a similar fashion as a vacuum booster.
An older solution is the hydrovac like you have, and some slightly newer versions of the same thing could be substituted.
Grigg | | | | | Joined: Dec 2009 Posts: 19 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2009 Posts: 19 | I have a 52 6400 and I put a on the firewall split system. The vac booster/master set up was $200 at NAPA and went to a chevy 1-1/2 ton, 1997 I think. Part No# 54-71046.Used the pedal from a S-10 and built the support for it. My rear wheel cylinders were good so I just put on new front ones. I had just cleaned the seat with WD-40 and went to try them. I was slammed into the steering wheel with great force. This is now a split system so if one brake line goes bad you still have brakes. Bob
