2 members (Brian Moore, panel fan), 166 guests, and 4 robots.
Topics128,107
Posts1,056,225
Members48,436
#655828 06/19/2010 12:24 AM
Does anyone know how to Take out and Install the Vent Window and door Window on the Task Force trucks without scraching paint and ruining things?
1955.1 Chevy 3600 NAPCO Truck
1957 Chevy 6400 US FOREST SERVICE
Here's a long list of all my STUFF!
the procedure is in the manual, doing it without causing damage to the door is your responsibility wink
Just did it the other day. Real pain in the rear to do this job. It only took me 45 minutes but I had to replace a broken window so I didn't have to be careful about it. Follow the procedures as outlined in the link above. The real manual has more pictures to look at, so the link above may get a little confusing without the extra diagrams. Take off door handles, sheet metal portion in middle of door, screws above and to the side of glass, trim surrounding top of windows, two weatherstrip panels: 1 on inside and 1 on outside of window but in the door (these sort of snug the glass as it moves up or down), and I'm sure there are a few more screws that need to be removed. With the window all the way up, or close to it, you can remove the glass screws (2 of them).
The hardest part is actually pulling the window portion out. It is very tight! Pulling my old glass out, i beat it with a mallet and somehow wiggled it out. Inserting the new glass is a little easier because you can push down on the window and you have more leverage.
Doing all this carefully is the only way to prevent damage on the new window. Maybe putting tape on the lower portion of the window would help (this is where you need a screwdriver to pry the weatherstrip panels).
---Casey
"Effective leadership is putting first things first. Effective management is discipline, carrying it out."
---Casey---
http://s676.photobucket.com/albums/vv127/davisears/?albumview=slideshow
Holly Smokes! Thanks so much for all your input!
I need to replace my window glass as well. Can I reuse the original frame and just install the glass?
1958 Apache Shortbed Fleetside
definitely - the only problem you may have is getting the small barrel screws out of the lower frame, but those are available from some vendors [Carter for one]
Thanks. Luckily I have good glass in a frame already that I picked up for $20 at a garage sale.
