7 members (KEVINSKI, ronsway, Otto Skorzeny, Greg_H, 1955 1 Series, TrknGMC, TooMany2count),
157
Mod | | | Forums66 Topics128,142 Posts1,056,481 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2009 Posts: 797 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 797 | The fuel gauge on my '48 Chevy 1/2 ton p.u. does not work. On the backside of the gauge cluster the "cardboard? bridge" between the two posts is missing. Is this a critical thing to have in place? Wht purpose did it serve? Please advise. Thanks. | | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | It is an electrical insulator to keep the two wires from grounding to the gauge housing. You could make an insulator out of a piece of plastic (like a milk jug). | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Jun 2009 Posts: 797 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 797 | Thanks for the info. All other things aside, could this explain why the fuel gauge will not register? I realize that I perhaps have other trouble-shooting to think into. | | | | | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | It is possible, if the sender side of the guage is grounded, it will read empty all the time. You can do this quick test to help isolate the problem. Disconnect the sender wire at the tank, if the guage now swings to full, guage is good, trouble is in the sender itself. While you're looking at the tank, make sure the sender wire is actually hooked to the sender terminal at the tank, and not the ground terminal.
If disconnecting the sender wire at the tank has no effect on the guage, make sure the sender post on the guage isn't grounded or that the sender wire itself isn't pinched under something and grounded, and make sure "hot" side of the guage is actually getting voltage when you turn the key on (you can check this with a trouble light or a voltmeter). | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Thanks for the correction Gauge pic Did the Gauge ever work? Have you converted to 12Volt? Is it the original sending unit? My truck was converted to 12 volt, sending unit was froze in one position, and the gauge was 6 volt. Had to repair all of that. Just things to look at Good luck | | | | | Joined: Jun 2009 Posts: 797 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 797 | Fuel gauge has not worked since I purchased the truck Spring 2009. All other gauges in cluster work. It is still 6V. Sending unit was replaced prior to my purchase. Float in sending unit was pulled and it does float as designed. Wiring has been examined and is correct and does not appear to be an issue. I AM BANKING ON THE LACK OF INSULATOR CITED EARLIER AND WILL ORDER KIT FROM L.M.C. IN THE A.M. Will attempt the other trouble-shooting at gauge posts as suggested if that does not do the trick. Could gauge cluster/chrome bezel and contact in dash panel be an issue of concern? | | | | | Joined: Jun 2009 Posts: 797 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 797 | Also, please refresh my memory on correct wiring to the fuel gauge...when viewed from the back of the cluster (as in photo posted earlier), the upper left post goes to the ignition--correct? Likewise, the lower right post goes to the sending unit--correct? Please confirm. Thanks. | | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | Logic tells us that if you are empty, you need more juice, so power in goes to the empty side of the gauge. You want your tank to be full so wire the tank to the full side. This has worked on any gauge I have dealt with. | | | | | Joined: Jun 2009 Posts: 797 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 797 | So do I have this wiring reversed? Please clarify. What happens if this is powered up with wires reversed? | | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | It will either fry the gauge or make it read empty all the time. | | | | | Joined: May 2010 Posts: 42 New Guy | | New Guy Joined: May 2010 Posts: 42 | Any idea what might be happening if my gauge reads Full all of the time when ignition key is on? I am thinking the float might be stuck, but it would be great to get other ideas before I drain the tank, etc. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | The lead between the gauge and the sender might be disconnected or broken.
