0 members (), 140 guests, and 1 robot.
Topics128,080
Posts1,055,953
Members48,430
#672628 08/24/2010 12:51 PM
truck i bought dosent seem to have a relay for headlights.
is one ness?
what's the downside?
it ain't YOURS 'till it ain't stock!
1951 chevy 3100
What year?
What type of bulbs?
6v or 12v?
Original gauge wire?
If all original, and there was no relay originally, none is necessary. There has been no downside that I am aware of on my 6v 47-55 trucks with original wiring and bulbs.
However, some people add them, even in original systems.
If you are using higher-power bulbs than the originals, a relay might be beneficial (in time, material, and safety) if you have to re-wire.
In general, the purpose of using the relay is to shorten the circuit from the battery to the headlights (and maybe to use heavier gauge wire). The idea is that there will be less resistance resulting in more power delivered to the lights (i.e. brighter lights).
They aren't necessary, by any means, just one of those "upgrades" that some people do. My '54 has an original-style harness and I think my headlights are plenty bright.
Sorry keep forgettin'
halogen bulbs -12v
12ga wire
early 70's chevy altenator/sb350
was wondering if it's too much draw on the headlight switch
1951 chevy 3100
That's exactly how mine is set up and no problems here. Lights are plenty bright. I have a brand new wiring harness (i.e. new wires and new connectors), so that might make a difference.
my harness is new as well.
guess i'll try swapping bulbs to check for bad connection causing dim headlight (still dim prob wiring?) or a dim bulb.
1951 chevy 3100
Every dim light problem I have ever had was bad grounds.
Most light problems period are bad grounds.
A relay will keep the load off the headlight switch and possibly make the lights brighter, but two relays, one each for high and low beam, triggered by the dimmer switch, will protect both switches. I've found that dimmers are much more prone to failure than dash switches.
A schematic of how all this ties together - lights to relay to switches/dimmers. I know the mad electrical relay wiring, but something that is specific to that particular application for those of us who are auto wiring deficient.
