3 members (homer52, Bill Hanlon, 1 invisible),
140
Mod | | | Forums66 Topics128,026 Posts1,055,408 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2010 Posts: 150 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2010 Posts: 150 | I have a tilt wheel column out of a 1977 Oldsmobile Cutlass. Does anyone have a good tip on how to mount it in the truck? Are there adapters for it? | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | If you post some pictures, I can help you. OR you can send them to me: [email protected]. Make sure you take good pic and of the mounting bracket that is on the column. There are several ways to mount. You may have to make a piece. I have pics of a piece I made from the original bracket. Please state the year of truck. What kind of steering system are you attaching the column to? I assume you are going to put in some kind of power steering?
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Jan 2010 Posts: 150 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2010 Posts: 150 | Thanks for the reply. I was out of the country for about a month and then really busy when I got back. I just saw the answer you gave to my question. I'll have to take some photos and send them. | | | | | Joined: Jan 2010 Posts: 150 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2010 Posts: 150 | The cab I have is a 1958 cab. I will attach the steering column to a 1973 Chevey Nova steering gear box. I have my truck sub-framed. I had the parts to connect the column to the steering gear box but they were stolen, as was the engine and transmission, by the mechanic I paid to install the parts. I'm about 10 years behind schedule. | | |
