| | | Forums66 Topics128,277 Posts1,058,453 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#67231 10/16/2006 5:29 PM | Joined: Oct 2006 Posts: 120 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 120 | I bought a '65 chevy stepside a few weeks ago through e bay... from the first minute I got in it I'm finding problems. It wont pass an inspection so I can not drive it legally on the road. I took it for check out drive and found that it slips out of reverse when I back up. Could that be that the shifter is loose or is it something more serious with the tranny? Appreciate any help. :confused: | | |
#67232 10/16/2006 5:50 PM | Joined: Apr 2005 Posts: 2,103 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,103 | It could be a combination of both. Check to see if the shift linkage is allowing the shifter arm to fully engage in the transmission. Also check for missing or worn-out shifter grommets or worn shift rods. You could disconnect the 1st/Rev shift rod and put it in reverse and back it up to see if it stays in gear. If it still falls out the problem is probably in the side cover and or worn shift forks inside the trans. Fred
#67233 10/16/2006 6:43 PM | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | What kind of transmission do you have ? 3 speed,4speed top loader,automatic ? 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
#67234 10/16/2006 7:14 PM | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | If it is a 3 speed column shift, check the cab mounts & engine mounts. Move to Arkansas where you can drive anything-no inspections at all. Brian | | |
#67235 10/16/2006 11:32 PM | Joined: Oct 2006 Posts: 120 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 120 | It is an automatic 3 speed. When I put it in park the shifter goes past the normal stopping point. Is the neutral/park safety switch also part of the back up lights switch or if not where does the back up switch go. I'll check out the mounts tomorrow. Jim | | |
#67236 10/17/2006 2:40 AM | Joined: Oct 2006 Posts: 120 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 120 | Originally posted by 64fleetside: If it is a 3 speed column shift, check the cab mounts & engine mounts. Move to Arkansas where you can drive anything-no inspections at all. Brian Hey Brian Next you'll tell me you use the Fred Flintstone braking method  | | |
#67237 10/17/2006 2:25 PM | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | [QUOHey Brian Next you'll tell me you use the Fred Flintstone braking method  [/QB][/QUOTE] I am sure there are some here that do! Brian | | |
