8 members (tclederman, Hotrod Lincoln, ChevyBlue, moparguy, mk72, farmallb, Opelika Tom, Otto Skorzeny), 179 guests, and 1 robot.
Topics128,089
Posts1,055,988
Members48,430
#67231 10/16/2006 5:29 PM
I bought a '65 chevy stepside a few weeks ago through e bay... from the first minute I got in it I'm finding problems. It wont pass an inspection so I can not drive it legally on the road. I took it for check out drive and found that it slips out of reverse when I back up. Could that be that the shifter is loose or is it something more serious with the tranny?
Appreciate any help. :confused:
#67232 10/16/2006 5:50 PM
It could be a combination of both. Check to see if the shift linkage is allowing the shifter arm to fully engage in the transmission. Also check for missing or worn-out shifter grommets or worn shift rods. You could disconnect the 1st/Rev shift rod and put it in reverse and back it up to see if it stays in gear. If it still falls out the problem is probably in the side cover and or worn shift forks inside the trans. Fred
#67233 10/16/2006 6:43 PM
What kind of transmission do you have ? 3 speed,4speed top loader,automatic ?
1951 3100 Chevrolet
#67234 10/16/2006 7:14 PM
If it is a 3 speed column shift, check the cab mounts & engine mounts. Move to Arkansas where you can drive anything-no inspections at all. Brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
#67235 10/16/2006 11:32 PM
It is an automatic 3 speed. When I put it in park the shifter goes past the normal stopping point.
Is the neutral/park safety switch also part of the back up lights switch or if not where does the back up switch go.
I'll check out the mounts tomorrow. Jim
#67236 10/17/2006 2:40 AM
Quote
Hey Brian Next you'll tell me you use the Fred Flintstone braking method wink
#67237 10/17/2006 2:25 PM
[QUOHey Brian Next you'll tell me you use the Fred Flintstone braking method wink [/QB][/QUOTE] I am sure there are some here that do! Brian
