8 members (Phak1, 68ironhead, Bill Hanlon, Peggy M, 3B, Oswald, elhippie64, 1 invisible), 145 guests, and 1 robot.
Topics128,154
Posts1,056,834
Members48,456
While looking at my distributor and the vac advance clamp I noticed that about 3/8" to 1/2" gap between the top of the clamp and a sholder on the distributer shaft.Is this normal or is my distributor not seated into the oil pump? I have been driving it that way for about 2000 miles.Oil pressure is good at first startup and drive,but at highway speeds only about 5-6 lbs.
Riding in the Passing Lane
Sounds like its not down as far as it should be but is still engaugeing the pump. That is a little low for the oil pressure but there is no in between. It,s either turning or not. You might use a heavier grade oil.
1972 Chevy c10 Cheyenne Super
