| | | Forums66 Topics128,119 Posts1,056,648 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#67180 10/15/2006 3:12 PM | Joined: Mar 2006 Posts: 483 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 483 | While looking at my distributor and the vac advance clamp I noticed that about 3/8" to 1/2" gap between the top of the clamp and a sholder on the distributer shaft.Is this normal or is my distributor not seated into the oil pump? I have been driving it that way for about 2000 miles.Oil pressure is good at first startup and drive,but at highway speeds only about 5-6 lbs. | | |
#67181 10/15/2006 3:22 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Sounds like its not down as far as it should be but is still engaugeing the pump. That is a little low for the oil pressure but there is no in between. It,s either turning or not. You might use a heavier grade oil. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
