| | | Forums66 Topics128,167 Posts1,057,020 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2004 Posts: 3 Junior Member | | Junior Member Joined: Dec 2004 Posts: 3 | I would like detail instructions on grafting in a camaro sub frame into a 1954 and a 1956 chevy pick-up.Pictures would help a lot. Thank You Larry
ubb
| | | | | Joined: Sep 2003 Posts: 66 New Guy | | New Guy Joined: Sep 2003 Posts: 66 | Larry, I believe I saw this in an issue of one of the truck mags some time ago, I will see if I can find the issue. I used a rear steer camaro clip under my 39 and it worked fine......Dale
1939 GMC 1953 HD PANHEAD 1930 Chevy 3 window coupe
#6718 01/03/2005 12:08 AM | Joined: Sep 2003 Posts: 66 New Guy | | New Guy Joined: Sep 2003 Posts: 66 | Larry, finally found the issue. March 2001 of "Truckin'" they put a front steer camaro clip into a 55 chevy truck. Not very detailed but enough info to get you thinking, maybe two dozen pics. Hope this helps.............Dale
#6719 01/03/2005 12:12 AM | Joined: Sep 2003 Posts: 66 New Guy | | New Guy Joined: Sep 2003 Posts: 66 | Larry, forgot to mention this clip will lower the truck approx 4 inches.........
