5 members (1955 1 Series, 3800GUY, Shade Baby, TooMany2count, Bluesky54), 131 guests, and 2 robots.
Topics128,110
Posts1,056,274
Members48,439
#671623 08/19/2010 10:32 PM
I just found why the steering on my 63 has so much play in it, the steering gear box housing is broke right at the bolt tab (bottom right as you look through wheel well).
Does anyone know where to find replacement,I checked my classic industries catalog with no luck
I have a used manual box that came off my 64 C20. If it will fit I will sell it to you pretty cheap. Not sure about the fit tho.....
The glass is twice as big as it needs to be.
The K-series shaft is horizaontal and the C-series is vertical. They are not interchangable. There are places that rebuild, but you need a good housing. Maybe it can be welded?
LMC has them but they are for 64-66, dont know if they will fit 63
thanks for all the help, belive i found a used one
