0 members (), 109 guests, and 2 robots.
Topics128,167
Posts1,057,021
Members48,458
Junior Member
Junior Member
I would like detail instructions on grafting in a camaro sub frame into a 1954 and a 1956 chevy pick-up.Pictures would help a lot.
Thank You
Larry
ubb
Larry, I believe I saw this in an issue of one of the truck mags some time ago, I will see if I can find the issue. I used a rear steer camaro clip under my 39 and it worked fine......Dale
1939 GMC
1953 HD PANHEAD
1930 Chevy 3 window coupe
Larry, finally found the issue. March 2001 of "Truckin'" they put a front steer camaro clip into a 55 chevy truck. Not very detailed but enough info to get you thinking, maybe two dozen pics. Hope this helps.............Dale
1939 GMC
1953 HD PANHEAD
Larry, forgot to mention this clip will lower the truck approx 4 inches.........
1939 GMC
1953 HD PANHEAD
