Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
7 members (VEW, Stovebolt48, SNOYL, Hugh63c10, Cletus1950, Barnfind49, Gib70), 82 guests, and 4 robots.
Topics128,281
Posts1,058,460
Members48,490
#671235 08/18/2010 11:56 AM
Will the hood from a 1935 truck with 4 vertical louvers fit on my 1936 truck. The correct hood for 1936 should have 2 horizontal louvers. Thanks for the help
maplefrm #671251 08/18/2010 1:37 PM
OLTrucks
Unregistered
OLTrucks
Unregistered
I must ask, Is your 1936 a high or low cab?
high cab being the earlier and having three door hinges per door and low cab having two hinges per door. If it is a high cab I think it should fit.I might have to see if I can find a sample of each to check for sure.
#671330 08/18/2010 6:16 PM
My truck is a low cab with the 2 door hinges. I have the top of the hood but no side panels and I would like to enclose the motor again. Thanks.
maplefrm #672556 08/24/2010 2:24 AM
i have a low cab 36 with the 35 hood . fits fine ..
maplefrm #672563 08/24/2010 2:48 AM
I have a hood that came off a 38. hood and sides. will it fit??
lugnut123 #673324 08/26/2010 11:38 PM
I found a hood and side panels from a '34-'35 truck and will use them until I can find the 1936 model. Thanks for the help.
maplefrm #676949 09/10/2010 11:23 PM
I received the hood from the '34-'35 Chevrolet truck. It fits lengthwise (cowl to radiator shell) The side panels are the correct length at the cowl (up & down) but the front edge of the side panels are about 1/1/2" too short. So, guess I'll keep looking for the correct '36 hood or just the side panels.
Thanks for all the help so far.
