| | | Forums66 Topics128,035 Posts1,055,564 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2009 Posts: 164 Shop Shark | | Shop Shark Joined: Apr 2009 Posts: 164 | I picked up these tools from the estate sale of a 50's chevy collector. http://s830.photobucket.com/albums/zz230/19511979chevgmc/tools/ the one that looks like a screwdriver has a piece of tape that says "6 cyl valve adj" is it? and how do I use it?. then theres the big "thing" that I think is for magnafluxing. and a little ratchet, adjuster thingy?? that is stamped "K-D NO.339" any ideas? | | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | You would use them both together. the ratchet loosens the nut and the driver adjusts the valve. The other thing, I have no clue. | | | | | Joined: Nov 2001 Posts: 1,517 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,517 | Those are very rare tools. I think you got them way too cheap. | | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | If that valve adjustment set turns out to be for a Ford Model T, I saw on the H.A.M.B. somebody was looking for one. | | | | | Joined: Apr 2009 Posts: 164 Shop Shark | | Shop Shark Joined: Apr 2009 Posts: 164 | yep Marty, now I just need to figure out how to use them.
| | | | | Joined: Aug 2005 Posts: 1,186 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 1,186 | I have a screwdriver like that I got from an old Chevrolet mechanic. It makes it so the screwdriver doesn't slide off while adjusting valves with the engine running. I really like mine!
Bruce | | | | | Joined: Mar 2005 Posts: 637 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 637 | I have a screwdriver my dad made that has the blade completely hidden in the metal sleeve. It is for adjusting valves with the engine running so it will not slip off the adjuster while the engine is running. I have used it lots of times before I got the tool with a socket and screwdriver combination for adjusting valves and working the lock nut at the same time.
