5 members (porsche, Bill Hanlon, Steelonsteel, ‘37ChevyPU, carbking), 99 guests, and 1 robot.
Topics128,051
Posts1,055,767
#670767 08/16/2010 4:37 PM
Hi there! Can anyone tell me how to get the steering column out of a '50 Chevy AD pick up? You know, it's the type that the column is attached directly to the steering gear. Neither the gear or the wheel will fit thru the hole in the firewall. HA! Thanx. Nev.
Remove one or the other. I took the wheel off to get mine out.
1953 Chevrolet 3600
Fried Green T'mater (Vern)
Caution: Political Statement
Pull the steering wheel, remove the pitman arm from the box, remove the bolts holding the box to the frame, and remove the box and column as a unit from underneath the truck. You'll have to jack the truck up fairly high, use good jackstands and BE SAFE!!!
Also, if it will help, you can separate the column from the gear box at the flange where it connects on top. That might give you a little more flexibility in getting it out from under the truck.
Better start learning to dismantle if you're planning on restoring the truck. If you look real close you'll be able to figure out how things come apart.
~Jim
GW.
Get a SAWZall and cuy through the whole thing just above the box.That way you can hook up to late model steering.
Sully
