2 members (Hotrod Lincoln, KCMongo), 59 guests, and 1 robot.
Topics128,050
Posts1,055,639
#67069 10/11/2006 1:53 PM
Are the distributors different between the 216 and the 235? Are they different than the 261?
TIA
Dennis
#67070 10/11/2006 3:14 PM
The 1954 and later truck 235 and 261 distributors are interchangeable.
The 1954 (and '53 Powerglide ??) automobile distributors can work on 54-62 trucks; however, the mechanical advance springs/weights might be different, and the geometry of the vacuum advance units are different.
I think I remember correctly that the pre-54 truck 216/235 distributors are different from the 54 and later distributors (but, this might just be the cap and rotor). Maybe someone who knows will clarify this.
#67071 10/11/2006 8:13 PM
The master parts catalog will answer this question: http://chevy.tocmp.com/1929_54chevyparts/16/729.HTM
Mike Barnes
1950 GMC 1-ton pickup
#67072 10/11/2006 9:10 PM
Apprentice
Apprentice
Napa list the same distributors for the 216 & 235 thru the last one in 1962. The cap & rotor is taller on the 235 but if you change both they work ok.
Thanks, Kelly
53 3100
http://www.cravy.com/53-3100/LadyAfterRats.jpg
