Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
2 members (Peggy M, MNSmith), 240 guests, and 4 robots.
Topics128,282
Posts1,058,495
Members48,490
#67052 10/11/2006 3:31 AM
I filled up my gas tank this weekend. A few hours later in the hot sun, the gas was flowing out of the filler neck (with cap on). Obviously it had built up vapors inside and was pushing the gas out.
Now at first I thought I had filled too full. I siphoned it out of the filler neck. Next day it did it again though not as bad.
Any ideas on the cause? Did I simply fill too full or is there a problem with the vapor line?
1951 Chevy 3100 w/235
#67053 10/11/2006 4:13 AM
Not vapors, the fuel expands when it gets hot and flows out. Don't fill it if you are not going to drive immediately in hot weather.
#67054 10/11/2006 11:04 AM
Mine does it too and I blame the new nozzles. I listen as it's filling - you can hear when the fuel nears the top - and shut it off before it clicks on its own. Also, if there is a slope at the station, put the neck on the low side.
