2 members (Peggy M, Simso),
291
9
Mod | | | Forums66 Topics128,077 Posts1,056,034 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2005 Posts: 41 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 41 | Does anyone know where I can get a fitting for adapting a 216 flare fitting on the temp sensor to a 235 with a 3/4 hole in hear? everything I can find the center hole is too small to fit the sensor. I would like to keep the original gauges in my 53.
Chevy Pete
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy 5253chevyman, maybe I'm missing something, but if you have the original fitting, why not just buy the appropriate size pipe bushing to make the smaller fitting fit the larger hole? | | | | | Joined: Nov 2005 Posts: 41 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 41 | 3B That was my first try but the threads on the temp sensor are flare threads and the pipe bushings are just a little to big.
Chevy Pete
| | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | I think you need to clarify that "flare fitting" part, didn't the 216 years all have mechanical gauges with a threaded bulb on the end? a flare fitting is for tubing with a flare on the end for sealing liquid .... any temp sender I've ever seen has standard brass pipe threads and will fit various brass plumbing fittings .... maybe you're actually dealing with the oil pressure gauge?
Bill | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Nov 2005 Posts: 41 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 41 | Thanks tclederman, that is exactly what I need. I will check with NAPA again tomorrow and if they don't have it, I know where to go.
Chevy Pete
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Pete, A while back, someone posted NAPA (Balkamp) part #701-1542 for that fitting. If you check it out, post back here if it works or not. http://www.napaonline.com/Search/Detail.aspx?R=BK_7011542_0282384745The picture does not look right but maybe it is a bad photo. | | | | | Joined: Nov 2005 Posts: 41 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 41 | Tim, NAPA did not have one of these in stock but there picture was the same as this one. This fitting looks like it would go into a 216 head with the small end for a new style temp sensor.
As it turns out one of my street rod buddies had one of the fittings I needed but thanks for your help anyway. Pete
Chevy Pete
Excellent - get it running and let us know.
