5 members (Otto Skorzeny, KEVINSKI, Hanks custodian, SmalltownTRKGuy, 1 invisible), 69 guests, and 7 robots.
Topics128,077
Posts1,056,032
Members48,433
#670188 08/13/2010 8:04 PM
Does anyone know where I can get a fitting for adapting a 216 flare fitting on the temp sensor to a 235 with a 3/4 hole in hear? everything I can find the center hole is too small to fit the sensor. I would like to keep the original gauges in my 53.
Chevy Pete
3B Offline
Hy 5253chevyman, maybe I'm missing something, but if you have the original fitting, why not just buy the appropriate size pipe bushing to make the smaller fitting fit the larger hole?
3B
That was my first try but the threads on the temp sensor are flare threads and the pipe bushings are just a little to big.
Chevy Pete
I think you need to clarify that "flare fitting" part, didn't the 216 years all have mechanical gauges with a threaded bulb on the end? a flare fitting is for tubing with a flare on the end for sealing liquid .... any temp sender I've ever seen has standard brass pipe threads and will fit various brass plumbing fittings .... maybe you're actually dealing with the oil pressure gauge?
Thanks tclederman,
that is exactly what I need. I will check with NAPA again tomorrow and if they don't have it, I know where to go.
Chevy Pete
Pete,
A while back, someone posted NAPA (Balkamp) part #701-1542 for that fitting. If you check it out, post back here if it works or not.
http://www.napaonline.com/Search/Detail.aspx?R=BK_7011542_0282384745
The picture does not look right but maybe it is a bad photo.
Tim,
NAPA did not have one of these in stock but there picture was the same as this one. This fitting looks like it would go into a 216 head with the small end for a new style temp sensor.
As it turns out one of my street rod buddies had one of the fittings I needed but thanks for your help anyway.
Pete
Chevy Pete
Pete,
Excellent - get it running and let us know.
