0 members (), 128 guests, and 2 robots.
Topics128,167
Posts1,057,021
Members48,458
I had a local mechanic shop tell me that I could change out the gearing in the rear end to improve driving since I won't be using this truck for extremely heavy use. Does anyone have some advice on this?
What series GMC is it. Different sizes had different ratios to begin with. If its a 100 series, you would now have a 4.11. Aftermarket 3.55 is available.
It's a 1 1/2 ton with a 2 speed rear.
Could be a 5.17/7.15, 5.83/8.10 or a 6.33/8.81. There are no aftermarket ringsets made for these. If you have the slow ratio, all you can do is find a donor truck with the faster gears.
