1 members (TexasJim50), 119 guests, and 2 robots.
Topics128,265
Posts1,058,364
Members48,485
#669682 08/12/2010 12:54 AM
U
U Offline
Hi,
When I turn on my lights the amp needle on my gauge spikes to the left from normal..
what could be causing this? This will also happen when the engine is running.
New wire harness from YNZ. I have checked and the wires (as far as I can tell) are wired right. I checked and followed the manual.
Thanks guys!
Jon
1957 Chevy 1/2-Ton Truck
More pix
The coldest winter I ever saw was a summer I spent in San Francisco M. Twain
If at first you don't succeed...skydiving is not for you!
If you don't like my carbon foot print, stick it up your Prius!!
UnklRod #669698 08/12/2010 2:26 AM
It is normal it's just the lag time before the gen. or alt. kicks in. Just showing the amprage flow.do'nt worry be happy it swings back to charge.
theres a tool for every job,and that tool is a hammer. it's easy to give advice if it's not your pocket book at stake. A well thought out plan,Is nothing. Untill exacuted twice.
49 floyd #669701 08/12/2010 2:39 AM
if it just spikes and returns, yes, no worry .... if it stays like that whenever the lights are on, either the generator isn't genning or there's a short someplace - under any condition, the ammeter shows the flow into or out of the battery, any discharge shown [like during starting] should immediately jump toward neutral and quickly show a charging condition, replacing the juice drained
squeeze #669714 08/12/2010 3:09 AM
U
U Offline
I will keep an eye on it. It moves to the left just a bit with the parking lights only...but when I turn on head lights it moves even more to the left.
I am not running the truck that much as it is on jacks and I keep the battery (poss) lead off the battery. the battery is close to needing to be charged...
Cool...thanks guys just want to be sure it is OK
More pix
UnklRod #669822 08/12/2010 1:41 PM
Ex Hall Monitor
Ex Hall Monitor
Don't let it sit in a discharged state. You'll ruin the battery.
Tiny #669971 08/12/2010 11:32 PM
U
U Offline
How do I check if the gen is charging the battery?
More pix
UnklRod #669974 08/13/2010 12:10 AM
Ex Hall Monitor
Ex Hall Monitor
Start it up and put a volt meter across the terminals while it's running (charging). Should show a voltage of around 14 volts. A good 12v battery will often show 13.8 volts fully charged.
Tiny #670034 08/13/2010 4:55 AM
You can to tell by the amp gauge if it is charging. If it shows a charge, it is charging.
You need to start with a charged battery though. It doesn't take very many times of starting and shutting it off without letting the battery recover, to discharge the battery.
Cletis #670051 08/13/2010 6:15 AM
U
U Offline
OK,
Thanks!
I will check with volt meter. Then I will start to trust what the gauge is telling me...
Jon
More pix
UnklRod #670074 08/13/2010 11:21 AM
Regarding you battery question, if you charge your battery with a small charger, when it is fully charged it will be taking about 2 amps or so. If the battery is in poor shape, it will take a lot more continuously. Sometimes when the battery is completely shot, it will not take a charging current at all.
1951 1 Ton Completed
